17hp Briggs Engine
Jeff M
02-12-2005 12:08:55
Hi everyone,
I have a 17 HP Briggs Intek engine that was new in 1999. It has a lot of hours on it and has suddenly started using oil. I took the head off and found a 3/8" carbon streak that goes from the piston to the OHV pocket. Is this a pretty good indicator I have a blown head gasket and don"t really need new rings?
Thank you for any help you can give me.
JT
02-13-2005 14:17:16
 Re: 17hp Briggs Engine in reply to Jeff M, 02-12-2005 12:08:55
Jeff,
That is a very common problem with 17hp Intek engines. Briggs has increased the material in the head gasket to stop this from happening again.The funny part, ususally if blows the gasket on the back side of the gasket, so you do not see it unless you take off head gasket. Clean, new head gasket, should be back good again.
Jim
TK
02-13-2005 11:32:54
I've seen briggs OHV valve engines do that. They blow out that relativly narrow piece of gasket between the cylinder and the OHV/pushrod chamber. What happens then is the oil in the crankcase gets into the cylinder through that leak, and gets burned. The smoke level is usually pretty bad.
Rings usually gradually get worse and worse over time, as they wear. The headgasket issue happens suddenly, usually with very little or no warning.
