1872 Hydro Cub Cadet
ss20
04-20-2005 19:20:23
Just purchased a used 1872. Runs great, cut great. Only problem, slow going up hill until you move the lever all the way up. After you get to the top it accelarates and takes off wide open until you move the lever down somw. Is this a problem with the Hyrostatic drive?
R Bedell
04-21-2005 04:13:04
 Re: 1872 Hydro Cub Cadet in reply to ss20, 04-20-2005 19:20:23
In addition, make sure the Hydro Oil is in good condition (reddish in color) and up to level. When was the Hydro Filter last changed also .....????
David A. Hodson
04-20-2005 20:18:56
common problem with later Cub's check linkage- remove panel on frame inbetween legs if sitting on seat, and also look under fender on left side over left rear tire you should see a bracket wit two springs (one inside the other) with buttons on each end check to make sure not bad grooves worn into plates LOL David
sps20
04-21-2005 16:42:13
 Re: 1872 Hydro Cub Cadet in reply to David A. Hodson, 04-20-2005 20:18:56
Will change Fluid and check the linkage this week end. I really appreciate the help guys.
Steve
