20.5 B S Engine Surging
Jim52
05-29-2005 12:56:13
Hello all:
I have a 20.5 HP Briggs/Stratton garden tractor engine, about 7 years old, that has intermittent surging. I was thinking it was a fuel problem; changed the fuel filter, but it's still there. Thought there might be water in the gas, so I got some gas dryer, and tried that. Still no help. I'm starting to think it"s something more serious (head gasket???). It's very rhythmic, and happens at all engine speeds. Occasionally, pulling out the choke will help a little bit. Then, other times, it will run perfectly for extended periods. Could there be some crud working its way through the system and getting hung up in the fuel line or a carb port occasionally? Am I looking at a carb rebuild? Any hints would be appreciated. Thanks.
stronics
05-29-2005 16:17:15
 Re: 20.5 B S Engine Surging in reply to Jim52, 05-29-2005 12:56:13
It is the carb most likely. Dirt, water, gravel and moss. Take it off and clean every orffice and it shold be fine.
David
