18hp v twin briggs surging
mattd
06-12-2005 19:12:26
i just got an older grasshopper 718. it has the 18 hp v-twin briggs in it. and the probelm i have is at half throttle and below the engine will speed up and slow down on its own even if its moving and blades turning. i am thinking this is a govenor issue. i dont have any experience with this particular motor. it isnt really a probelm but i would like to get it fixed. thanks in advance
matt
Bob
06-12-2005 21:49:49
 Re: 18hp v twin briggs surging in reply to mattd, 06-12-2005 19:12:26
Improper carb adjustments (if it's old enough to have any), or some partially plugged passages can screw things up when the fuel flow is transitioning from the idle circuit to the load circuit, or vice-versa, causing surging.
mattd
06-13-2005 08:33:46
 Re: 18hp v twin briggs surging in reply to Bob, 06-12-2005 21:49:49
thanks bob, i will go take a look now
matt
