1730 Cub Cadet won't start when hot
Robert Wagner
06-23-2005 08:07:53
I have a 1730 Cub Cadet with twin cylinder kohler engine. After the engine is hot it will not restart iff I shut it off. There is no spark when this happens. It has begun stopped when it is hot now also. Does any one have a suggestion what might cause this problem
lester
06-24-2005 04:35:18
 Re: 1730 Cub Cadet won't start when hot in reply to Robert Wagner, 06-23-2005 08:07:53
Hi bob, in the process of doing mine rite now. ignition module is your problem, i just got done doing alot of different things after listening to alot of these nimrods that write in. like my dealer told me ignition module is the only device making spark , no spark bad module. if you have a low oil sensor on it just pull the wire on the plug (sensor looks like spark plug)this could be faulty and also prevent starting. these guys will tell you it happens when its hot, well i'd mow my 2 acres no problem the next week when i'd go to start her nothing. i have the 1811 cub, got a 18 hp magnum in mine. had to pull the engine, alot of 3/8s sheet metal screws to remove on the muffler baffels. not sure if you have to pull yours. if you do take the mounting plate out instead of 4 mounting bolts it's only 6 holding the plate and much easier to do, if it's anything like my cub. had guys telling 2,4 and 6 hrs to do job, plan on the day my friend. it was easy to do just time consuming. im a house painter but mechanicly inclined, the site i used for parts and diagrams was cortlandmower.com/parts.
R Bedell
06-25-2005 02:55:58
 Re: 1730 Cub Cadet won't start when hot in reply to lester, 06-24-2005 04:35:18
ROTF....LMAO
lester
06-25-2005 05:22:38
 Re: 1730 Cub Cadet won't start when hot in reply to R Bedell, 06-25-2005 02:55:58
r bedell, whats this ROTF...LMAO ????? ??? IS THIS SOME KIND OF SPEACIAL LINGO???
R Bedell
06-25-2005 19:17:41
 Re: 1730 Cub Cadet won't start when hot in reply to lester, 06-25-2005 05:22:38
Rolling On the Floor....Laughing My A$$ Off
lester
06-26-2005 05:56:34
 Re: 1730 Cub Cadet won't start when hot in reply to R Bedell, 06-25-2005 19:17:41
why you laughing your a$$ off bidell, cause i don't make myself out like some super hero mechanic? i'm your regular joe like most of these guys who ask question when in doubt. all i really did was to let bob be aware of super heroes like you!!!!!
R Bedell
06-26-2005 07:55:14
 Re: 1730 Cub Cadet won't start when hot in reply to lester, 06-26-2005 05:56:34
I have NEVER professed to be a Super Hero. That is your phase. Seems funny to me, that you beg for free information, then when people take the time and effort to help you with your problem (free of charge), the thanks they get is being called "nimrods". LOOK IN THE MIRROR to see the biggest one. - LMAO
lester
06-26-2005 09:36:32
 Re: 1730 Cub Cadet won't start when hot in reply to R Bedell, 06-26-2005 07:55:14
I don't beg for anything, i have thanked those who deserved my thanks. Seems funny your the only one to take offense about being called a nimrod, if the shoe fits wear it!!!!!
R Bedell
06-26-2005 09:56:04
 Re: 1730 Cub Cadet won't start when hot in reply to lester, 06-26-2005 09:36:32
Yo Lister.....Whatever Dude....ROTF...LMAO
DON WATTS
06-23-2005 11:11:47
sounds like the ignition module or coil if you will needs replacing.
