18.5 twin briggs cant get starter off
fred555
06-25-2005 09:34:45
My 18.5hp twin cyl briggs & stratton-- got it mostly apart but there are 2 bolts behind the fly wheel that I can't get off. Is there a special tool, or should I remove something else to get to it?
stronics
06-25-2005 11:34:03
 Re: 18.5 twin briggs cant get starter off in reply to fred555, 06-25-2005 09:34:45
If you have all the sheet metal off and still can"t get to it you may have to remove the flywheel.
David
don watts
06-26-2005 07:49:02
 Re: 18.5 twin briggs cant get starter off in reply to stronics, 06-25-2005 11:34:03
like david suggested get a flywheel puller.its the best and safest way to keep from messing up the flywheel.but whatever you do dont beat on that flywheel.it could cause the magnets to break loose out of the flywheel.those pullers are not expensive and they sure save you a headache later. don
fred555
06-25-2005 12:46:12
I have all the metal off. I was told to try a box wrench, but can't get to it. How do i get the fly wheel off??
fred555
06-25-2005 12:39:16
stronics
06-26-2005 02:29:06
 Re: 18.5 twin briggs cant get starter off in reply to fred555, 06-25-2005 12:39:16
You will have to take the big nut off the center and then use a puller on the two holes provided for it. Then you may have to give the crankshaft a light tap to break it loose. If you can make by heating, grinding or bending a wrench to fit I'd do that first but it isn't a big deal getting the flywheel off really.
David
Rustyj14
06-29-2005 16:00:31
 Re: 18.5 twin briggs cant get starter off in reply to stronics, 06-26-2005 02:29:06
No, the big thing is getting the flywheel nut back on tightly! When you go to pull the flywheel with a puller, be sure to put the nut back on, just screw it down so that it is flush with the top of the threads! This will prevent any mushrooming of the crankshaft threads, and won't prevent the loosening of the flywheel! After you reinstall the flywheel and nut and washer, tighten the nut good and tight! Rustyj
