318 JD garden Tractor
John Carr III
08-23-2005 13:59:32
I have a 318 JD Garden Tractor good machine except after I have been mowing for awhile and the tractor is hot if I disengage the mower deck or shut the machine off, the mower won"t reingage until the tractor cools down. Anybody had this problem or have any suggestion?
Thanks
tractornutjd
08-23-2005 17:52:12
 Re: 318 JD garden Tractor in reply to John Carr III, 08-23-2005 13:59:32
Hi John. It sounds like your electromagnatic clutch is breaking down under heat. You can try to adjust it to .016 of an inch at all three slots by turning the three nuts that take a 9/16 wrench. This might get you by for a while, but the clutch sounds like its on its way out. tractornutjd.
JT
08-23-2005 17:50:04
Sounds as though you might have a pto clutch that needs adjusted or replaced. First thing to do is to check the gap between the plates of the clutch, this should be set at .010. If that is ok, then more than likley you have a clutch going bad.
