1990 Sears Companion
Mike WIS
09-01-2005 21:42:14
Ran across one of these for sale for $250.00 Supposed to be in great shape. Has 12 hp TEC. Any info on who made this for Sears? Any comments that someone would like to share? I checked the through the old posts on this board. There is very little posted on the Companion.
don watts
09-03-2005 06:47:32
 Re: 1990 Sears Companion in reply to Mike WIS, 09-01-2005 21:42:14
good little tractor .if i remember right its red in color and you can use model number 917.259280 and its made by american yard.good machine other than normal wear such as belts and blades.they were poplar when i was still in the field.use that model number and go to www.sears3.com and look at the break down.pretty reliable. don
JoeK
09-01-2005 22:24:50
Hard to tell mfg without seeing unit or knowing Model number."Companion" name is used by Sears for items they do not wish to label"Craftsman"and are usually lower cost items w/less warranty,or limited demand items to fill gaps in Sears mass inventory.Easiest way to ID is with Sears model Number.First 3 digits(247.,502.,131.,358.,917.,etc)usually IDs the mfg
