Blizzak rear tires on 15, 16 rear rims for snow?
Boyd in Mn
09-03-2005 00:05:01
Anyone with any of the Case/Ingersoll or other brand tractors with 15",16" rear tires try putting Bridgestone Blizzak tires on the rear when plowing/blowing snow in the winter?
Pitch
09-03-2005 17:43:38
 Re: Blizzak rear tires on 15, 16 rear rims for sno in reply to Boyd in Mn, 09-03-2005 00:05:01
I don't think that snows would be much superior to the regular turfs that you have on. A snow tire such as the blizzak is designed for the tread to flex open and closed to altrenatly grip snow and release to clean it self. You just aren't going to generate the amount of stress at the light weight and low speed of your tractor for the tire to operate as designed. The most you can do for traction is to use chains and as much solid and liquid weight as you can muster.
