18.5 Briggs 2 cylinder
John M
09-07-2005 17:44:44
I am in the process of swapping the engine on an MTD mower for my stepdad,the one on the MTd threw a rod last week, and the one I put on is from a newer mower,but not new.(but newer than the one that blew) I dont know what brand of mower it was.First, I was having problems with it not running except when the choke was closed al the wya,but even then it wasnt right, so I swapped carbs and it helped but I think I still will have to rebuild one for it.The problem is that when you engage the mower deck or try to drive it, the engine boggs really bad and will cut off if you dont stop. At idle it floods and blows heavy black smoke, but idle it up and it will smooth out,just doent have any power.Any siggestions?
One more thing...
09-07-2005 17:45:46
 Re: 18.5 Briggs 2 cylinder in reply to John M, 09-07-2005 17:44:44
Howe can I check it to see if its charging?
