1961 cub cadet engine conversion
oldtractorguy
09-23-2005 08:20:28
I have a 1961 (original) cub cadet and was wondering how hard it would be to put a 6 to 7 hp one cylinder wisconson engine on tractor? Also would it be hard to make a belt tesioner clutch that uses a pulley on the engine with a short belt that runs to the drive shaft on the cub, it would use a belt tensioner pulley on the side that operated with the cub clutch? Please help.
oldrustycars
09-24-2005 16:57:54
 Re: 1961 cub cadet engine conversion in reply to oldtractorguy , 09-23-2005 08:20:28
if i recall, the AENL wisconsin is 8 horsepower, and is way bigger in physical size than the kohler. i'd stay with the kohler, im sure you can find one way cheaper than fooling around.
125 Hydo
09-24-2005 12:28:47
Link
Link
Link
Link
Okay. It is somewhat obvious that you may be interested in reisnstalling the K161 back in your Original. These sites will have members or as with the first two sponsors that sell both new and used parts. ALL the sites have great people that will be able to line you up with a K161 or the replacement K181. It would be less hassle than cutting up, welding and in general ruining a old Cub Cadet. As far as the 7 hp Wisconsin having more torque/power, whatever than the Kohler. Personal opinion is all that is. Someone that installed a non original engine always "beams with pride" at their accompishment. I've seen firsthand those 7 hp Kohler engines on an Original walk away with a wagon full or ear or shelled corn, pull a wagon load of hay, and even rake hay. One final thing... Yes, I happen to have a "spare" Kohler 7 hp for an Original. I know the engines are out there. You just have to be creative as I was to find one. I've provided you with four resources to acquire one. More if you utilize the contents within those sources. Summing up... sell the Wisconsin and get another Kohler... then have some fun with your little tractor.
oldtractorguy
09-24-2005 21:11:59
 Re: 1961 cub cadet engine conversion in reply to 125 Hydo, 09-24-2005 12:28:47
Engine bolts to frame perfectly, and hood goes over engine fine. I have to have a powerful tractor like this to be able to 6 inch plow through clay ground. And to plow deep snow.
BigBill
09-23-2005 19:14:46
Probably not all that hard as the Origanols are are pretty basic design. Can't say as I'd like seeing it done though, the Origanols are getting harder to find in decent shape & it's a lot easier parts for a Kohler than those old Wisconsins.
Buzzman72
09-23-2005 10:13:03
Original Kohler K-161 was 7 hp. Unless your Kohler's bad, what would you be gaining by replacing the Kohler with the Wisconsin?
oldtractorguy
09-23-2005 11:46:12
 Re: 1961 cub cadet engine conversion in reply to Buzzman72, 09-23-2005 10:13:03
because i have do not have the kohler.
Buzzman72
09-25-2005 12:57:36
 Re: 1961 cub cadet engine conversion in reply to oldtractorguy , 09-23-2005 11:46:12
NOW I understand.
Not sure about the belt tensioner down to the clutch assembly, why you'd need it with a proper belt. I suppose if you wanted to eliminate slippage, you could chuck the pulleys and make it a chain drive from the engine to the clutch...but I'd recommend fabricating some sort of chain guard, above AND below. [thinking out loud there...]
raider10
09-23-2005 11:01:38
i had a wisconsen 7 hp in my original and by all means it had way more low to mid range torque than the kohler.
