B S Pump Eng..
mi. kid
10-16-2005 14:01:33
5 HP eng. used now and then on pump. Went to start this year, will only run a short time with gas put in plug hole and chock on! Has large tank below carb. with some kind of foam in it. Elec.Ing. Is pickup tube pluged or diaph. stuck shut. Never had one like this apart.
Thanks for Your help!
shannon from ohio
10-16-2005 15:00:12
 Re: B S Pump Eng.. in reply to mi. kid, 10-16-2005 14:01:33
Yep,it needs a good cleaning?The foam keeps the gas from sloshing all around in the tank and affecting engine performance.
Kent of SW MO
10-16-2005 14:31:39
When you say now and then on the engines used, did you use fuel sabiliser in the fuel? If not you may have a varnished up carb/ fuel pump. Take it all a part and clean it up.
Kent
