1971 John Deere 112 starting problem
Guy Ransom
10-28-2005 14:03:58
Started my 112 and began to move but engine was sputtering like it needed gas. I tried choking it but it died. I tried to start it again but when I turned the key there was nothing. No starter, no sounds, completely dead. Any ideas where to start. Thanx
deanop
10-29-2005 18:41:20
 Re: 1971 John Deere 112 starting problem in reply to Guy Ransom, 10-28-2005 14:03:58
i've had wires go bad,,,,check those wires that are under the gas tank, behind the motor...some to fuses/connectors/solenoids. you might find one of these are not makin connection...ya might try wigglin these wires to track it down...doesn't sound like a fuel problem...
shannon from ohio
10-28-2005 23:22:47
Check connections on battery cables? They tend to get corroded and thus no contact.Also make sure you put it back in neutral.
