1985-318 JOHN DEERE LAWN TRACTOR
LARRY SAYLER
02-06-2006 17:39:50
MY BROTHER HAS A 1985 JOHN DEERE TRACTOR WTH NO POWER STERING AND NO LIFT,THE DEALER SAYS IT'S SHOT.JOHN DEERE WANTS $1900!!!!! PLUS $400-$500 FOR LABOR.WE WERE WONDERING IF ANYONE IN THE SOUTHERN MICHIGAN OR NORTHERN OHIO AREA REPAIRS THEM OR HAS A REBUILT ONE FOR SALE. THANKS
JT
02-07-2006 09:00:51
 Re: 1985-318 JOHN DEERE LAWN TRACTOR in reply to LARRY SAYLER, 02-06-2006 17:39:50
Did your dealer tell you what is shot about it? The complete hydro assembly is $1910.00. The charge pump, bolts on front of transmission is $420.00. Has he pressure checked anything. Does the machine still move, but no hydraulics? Could be valve messed up, will not let the fluid throught it. Unless the tranny has broken parts, it can be rebuilt, sounds to me like someone is looking for an easy project to make a few bucks.
Bob
02-07-2006 11:55:32
 Re: 1985-318 JOHN DEERE LAWN TRACTOR in reply to JT, 02-07-2006 09:00:51
third party image
Sometimes, when the charge pump goes, it tears up the hydro's input shaft.
Charge pump rotor kit (15): $180.00
Complete Charge pump (20): $420.00
Input shaft (35): $435.00
So, unless it is a real simple problem, a good used hydro is a LOT more cost effective!
Bob
02-07-2006 04:29:39
Check out the following two ebay auctions. (I've bought from him, he's a good guy, and he warrantees his stuff to work.)
7732531029
7735870592
jd b puller
02-06-2006 20:00:04
Larry, the part that is broken is called a charge pump. you MIGHT be lucky and just sheared the drive pin, or you might have wrecked the whole thing. Has the dealer taken it apart yet? His prices are not out of line.
