2145 Cub Cadet Won't Start
Ron In OHIO
04-05-2006 14:48:41
Hi All:
This almost 11-year old lawn tractor with a 14HP Onan engine will start several times in a row and then, all of a sudden won't start. It will crank just fine but won't fire. When it does start, it starts immediately. Any ideas on what's causing this intermittent problem?
Thanks, Ron
Kent of SW MO
04-07-2006 05:49:01
 Re: 2145 Cub Cadet Won't Start in reply to Ron In OHIO, 04-05-2006 14:48:41
Yes, I have seen ignition switch have an intermittent like this. It is rare which can make finding the problem a PITA.
Kent
Kent of SW MO
04-06-2006 06:26:24
Bad ignition switch maybe.
Kent
Ron In OHIO
04-06-2006 06:43:09
 Re: 2145 Cub Cadet Won't Start in reply to Kent of SW MO, 04-06-2006 06:26:24
Kent:
Would the starter still work, which it does since it cranks the engine, if the ignition swithch were bad?
Ron
