2135 not chargeing
Rich Griffin
05-10-2006 05:11:52
My light does not come on at the dash,but the bulb is ok. The oil lite comes on when switch is on,but not the gen light. The bat.runs down after a while. Anyone had this same problem and if so what is the fix? Thanks
Ernest
05-10-2006 09:06:44
 Re: 2135 not chargeing in reply to Rich Griffin, 05-10-2006 05:11:52
Had a 2185 cub cadet (almost but not quite) the same as 2135. The battery would run down and the pto would disengage. I found it to be the wire from the charging system inside one of the big wiring connectors were rotted apart. Cut and respliced 2 wires and great!
