318 john deere starting problems
amg520
09-10-2006 19:13:35
I have a 318 that wants to rarely start. The starter doesnt want to engage. I was wondering if that would be the solenoid or starter or wiring. Thanks to those who reply
tcwinkc
09-10-2006 20:25:06
 Re: 318 john deere starting problems in reply to amg520, 09-10-2006 19:13:35
If your machine is equipped with a solenoid shift style starter, you should have a relay kit installed. Relay is located at the right front corner of frame near engine. If not equipped with relay it can be purcahsed at local Deere dealer, I believe part no. is AM107421.If you have a bendix equipped onan, look at solenoid below battery tray, first check purple wire while trying to start, if you have voltage next check red 2/0 cable to starter,voltage? Test starter. If no voltage at purple 710 wire back track through safetys.If no volage through red cable ,replace solenoid. Any questions feel free to contact me.
