1811
scott weyand
11-04-2006 21:15:58
does a 1811 cub cadet have a cast or aliminumn rear end? and also is the body style the same or simmular to a 782? looking at buying one need to no some info. thanks scott
125 Hydro
11-04-2006 09:58:47
 Re: 1811 in reply to scott weyand, 11-04-2006 21:15:58
Some 782 series had a cast iron transmission i.e. the IH and VERY early CCC buiilt red series. The 1811 will have unless someone has changed over rearends an aluminum rear end. I wonder why you ask. If you are looking for reliability then both rearends hold up very well. Like anything if you abuse it you will lose it. If you want to plow then both will also work. You have to on both types of trannys make sure to use the correct bolts and torque to spec when installing a three point or Brinly hitch system.
R Bedell
11-05-2006 03:19:18
The 1811 is the same as a 782 except a tad newer and has a Kohler M-18 for a motor.
