17 hp Briggs
buckva
12-10-2006 14:09:43
Model 42A707 Type 2238E1 Code 9803205A. This engine is difficult to start. Acts like Tight engine due to compression. Good battery plus jumper/charger will just turn it over and finally started. Checked the flywheel key and it is not sheared-key ways line up. Battery is notthe problem and starter works but could be weak. When engine cold I can turn it with the palm of my hand on the flywheel screen but when it comes up on compression it is difficult and slow to turn. I sorta consider this normal. It starts fairly easily on one cylinder--spark plug removed on right bank with carb. forward. I have to use a 1/2 ratchet and large socket to turn it when hot. Engine presently in mtd yard machines but I plan to transplant it into a John Deere 70 once I have it workin good. It started actin up and was set aside 1/2 way thru this past mowin season. You are welcome to scold me for what I have if in you can tell me how to fix this scutter. Thanks in advance.
JT
12-14-2006 15:36:39
 Re: 17 hp Briggs in reply to buckva, 12-10-2006 14:09:43
What you are describing is a weak starter. This is a horizontally opposed flat head engine and normally valve clearance does not get out of wack like the OHV engines. I would probably, if it were mine, take off the starter, take it apart, clean the communtator, recut the mica in the commutator, check brushes, and put back together and try it. Also check armature for any burnt looking spots on it also. Just another thing to look at.
Junkyard Dog
12-10-2006 19:47:59
I believe this is overhead valve engine ? If so, chances are the valves are out adjustment - very common on these engines. I have rocker arms actually fall off of pushrods on these but seem to run "okay" until this happens
Wrench Spinner
12-10-2006 15:28:31
It could be any of three things, A weak starter (Try jumping directly to the starter). Valve clearance could be worn out of spec. causing the compression release on the cam lobe to not function properly or carbon build-up on the pistons/heads upping compression.
buckva
12-10-2006 16:05:57
 Re: 17 hp Briggs in reply to Wrench Spinner, 12-10-2006 15:28:31
Thanks for the reply. Compression release-- hadn't thought of that. Is there a maximum compression one should get for cold crankin compression and should the compression release be on only one or both cylinders. The possibly weak starter and carbon deposits I can check. Is there a method to adjust valves to get compression release workin again? Thanks again.
Wrench Spinner
12-10-2006 16:52:13
 Re: 17 hp Briggs in reply to buckva, 12-10-2006 16:05:57
Briggs does not list a max compression pressure due to the release incorporated into the cam lobes on both cylinders. All they say is compare readings from both cylinders and they should be within 25% of each other. From my experience you wouldn't want much over 120lbs. Check valve clearance by removing both valve covers then rotate each piston (which ever side is being checked)1/4" past top dead center compression stroke. With springs still installed .004"/.006" intake .007"/.009" exhaust.
With springs removed .006"/.008" intake .009"/.011" exhaust.
You may want to check the valve clearance before removing the heads just in case they need to be adjusted. That is done by removing the valves and either refacing the valve seat or grinding the valve stem.
buckva
12-10-2006 17:29:40
 Re: 17 hp Briggs in reply to Wrench Spinner, 12-10-2006 16:52:13
Thanks for the info. Have enough to keep me busy checkin it out for awhile.
