17.5 Briggs/ Stratton engine
Harold Vonsende
02-12-2007 12:13:48
Camshaft went flat on one lobe replaced it with new one backfires when trying to start. all spark gas and etc. is fine but still no help Flywheel key is fine. Briggs has had trouble with this but I cannot find the reamdy for this problem. Any suggestions? Thanks
Bob - MI
02-18-2007 07:38:11
 Re: 17.5 Briggs/ Stratton engine in reply to Harold Vonsenden, 02-12-2007 12:13:48
Backfiring sounds like timing. Cam could be one tooth off. Could also be a valve not going closed and allowing the flame out the exhaust as it fires. Either way it"s not good as you know.
The B&S website has help available on it if you can"t solve this one. A manual may come in handy here too.
Best of luck
pdi man
02-15-2007 16:12:56
make sure to go just past tdc to avoid having the comp release hold the ex valve open. re-adjust to .004-.006" and it should be good to go.
El Toro
02-13-2007 07:10:24
Sounds like the valve timing is off. Bring the piston to TDC on the compression stroke and see if both valves are closed. Hal
Greg_Ky
02-12-2007 23:50:17
If timing and valve lash are good it sounds like a burnt valve.
IH2444
02-12-2007 19:19:06
Did you replace /adjust the valve ? If not with a higher cam lobe it will probably no longer close properly.
Ryan - WI
02-12-2007 19:13:29
If I were you I would rotate the engine by hand and watch the valves. It seems to me that the timing is the culprit alright, perhaps there is an erraneous mark on the cam causing the timing to be off.
Bills1450
02-12-2007 19:06:09
Is it backfiring though exhaust or carb. ? Backfiring while trying to start is usually sign of either out of time or valve problem though as others suggested. Have you double checked these ?
Bob
02-12-2007 17:55:39
Did you check the valve clearances
shannon from ohio
02-12-2007 16:35:46
Did you make sure the timing marks we're correct upon reassembly??
Harold Vonsenden
02-12-2007 18:52:07
 Re: 17.5 Briggs/ Stratton engine in reply to shannon from ohio, 02-12-2007 16:35:46
The valves and also timing marks were all correct
