317jd
deene
02-26-2007 19:09:59
well i broke down and bought the 317..it does have a series 2 engine but i cant find an oil filter..i have seen the set ups for sale did they not all have these?..just an option?... where does it bolt on too?..thanks for all the help and advice..and im still looking for a 48 deck to fit this..just the shell would work as i have one but its pretty sad shape..thanks for all the previous advice
26Red
02-28-2007 10:00:18
 Re: 317jd in reply to deene, 02-26-2007 19:09:59
Try the weekendfreedommachine.com website; There is a kit you can put together for an oil filter. You can also find a deck for it there too.
Mike in MI
02-26-2007 19:30:10
The 317 W/Kohler engine did"nt have the oil filter"s setup. There wasn"t enought room to mount one. I have seen one on ebay this past week that one was mounted on a 317.
deene
02-27-2007 13:05:16
 Re: 317jd in reply to Mike in MI, 02-26-2007 19:30:10
thats the one i was refering to i just wondered where it went or how it was mounted..
Mike in MI
02-27-2007 13:59:40
 Re: 317jd in reply to deene, 02-27-2007 13:05:16
If this is the same one you and I are thinking about that has about 2-½ ft of hose and the body looks like it’s made of aluminum and takes the screw on filter that sold on ebay? I was thinking it could be mounted alone the right hand side of frame toward the backend of the tractor where would be less heat.
