18 hours briggs OHV
mss3020
03-21-2007 11:40:01
Im in the process of rebuilding my 18 hours OHV engine. Briggs. When adjusting the intake and exhaust valves where does the piston position need to be for both of those?
Thank you,
jd b puller
03-22-2007 20:42:36
 Re: 18 hours briggs OHV in reply to mss3020, 03-21-2007 11:40:01
Is that an Intek or Vangard? Or something else. On the Intek"s there"s a compression release at TDC so if you set the valves right at TDC, it won"t crank past compression. You need to go about 1/4 turn past TDC COMPRESSION STROKE on the Inteks.
joe csuti
03-21-2007 17:19:58
On single cyl 18 hp briggs recommends setting rocker clearance on both valves when piston past TDC & piston at 1/4" into it's downward travel,this way both pushrods on low spots of cam,also don't mixup pushrods,alum rod on intake valve,steel on exhaust.
Vern-MI
03-21-2007 13:01:25
TDC of the compression stroke.
Bob
03-21-2007 14:25:35
 Re: 18 hours briggs OHV in reply to Vern-MI, 03-21-2007 13:01:25
Double check that. At least SOME get set with the piston a certain measured distance from TDC.
