20 hp briggs straton engine trouble
SLH IN MO
03-23-2007 19:22:50
I'm trying to start my 20 hp twin cylinder briggs motor ,what is happening when the motor turns to compresson stroke it wants to stop I had this problem with a single cylinder OHV engine found out the valve clearance was to tight . this 20 hp motor is not OVH valve . Is there a certain way to adjust the valves.THANKS
Kent of SWMO
03-24-2007 10:21:47
 Re: 20 hp briggs straton engine trouble in reply to SLH IN MO , 03-23-2007 19:22:50
Please post Model Number, Type Number, and Code Number.
Kent
JT
03-24-2007 09:57:48
Valve clearance is not as critical on the side valves as the OHV engines. You could have a bad starter.
briggs
03-23-2007 21:38:08
What type of engine is this? Should say Intek, Quantum, Vangard, etc on the top. How old is it?
