20 Horse Kohler cutting out
Barry in Indian
04-30-2007 02:52:08
Hi everyone:
I have a Dixie Chopper with a 20 horse Kohler vertical shaft engine. The engine as new in 2004. This weekend while mowing I notice that when is is in heavy grass and pulling hard the engine cuts out and lack pawer. When in short grass or with the blade disengaged it purrs like a kitten. Anyone have any ideas what would make it cut out while pulling?
Barry in Indiana
joe csuti
05-01-2007 03:24:16
 Re: 20 Horse Kohler cutting out in reply to Barry in Indiana, 04-30-2007 02:52:08
El Toro is probably right about lean fuel supply,one other thing you could check,if eng m/mv or cn/cv series,some of these eng had a hi temp sw,from parts list I have,looks like it is mounted under a head bolt with 1 wire going to it,try disconnecting wire,see if this helps or cures problem,you may have a multi problem,lean fuel supply,restricted cooling,part going bad on tractor or deck,and overloading eng when you go into high grass,especially if grass damp/wet and high.
El Toro
04-30-2007 04:06:19
Your fuel filter may need replacing, it could be starving the engine for fuel when under heavy load. If the carburetor has a main jet adjusting screw it may need to be opened some. Hal
