2 questions
daniel in sc
05-02-2007 12:59:57
1. on the sears mower i have been working on, everywhere in the manual and on the engine says '3.0 reserve power'. the whole manual never mentions the word horsepower. i am guessing this is the same thing?
2. i got a flywheel puller from autozone. before i pull the flywheel, how will i get it pressed back on? sorry if this is a dumb question but i have never done this before. thanks.
daniel in sc
05-03-2007 10:19:48
 Re: 2 questions in reply to daniel in sc, 05-02-2007 12:59:57
the puller i got is a univeral puller that pulls with 3 arms on the outside edge of the flywheel. yall say that this will break it? where can i get a puller that utilizes the 3 holes? thanks.
JT
05-03-2007 15:10:35
 Re: 2 questions in reply to daniel in sc, 05-03-2007 10:19:48
get a steering wheel puller, basically a flat peice of steel with a puller screw in the middle and some holes in it to bolt to the lfywheel
Kent of SWMO
05-03-2007 06:18:57
Be careful if you use a puller on the outside of the flywheel. They are easy to break. You need a puller that uses the three untapped holes near the center of the flywheel. The right puller will have self-tapping screw to tap the holes.
Kent
Dannie
05-03-2007 00:57:18
I did not know AUTO ZONE even had a puller that would pull a flywheel on small air cool engines.My puller for Tec.is a flat piece of steel with 3 slots for screws that pulls from center of flywheel,or a striker that goes over crank and is hit with hammer.You do not want to pull from outside of flywheel unless you are going to replace it.
daniel in sc
05-02-2007 16:05:45
engine is a tecumseh model #143.314042 ser#1096B.
JT
05-02-2007 14:19:34
1.don't know what you are working on
2. the f/w and c/s are on an interferance taper, so when you put the f/w back on and tighten down, it will "lock" itself back to the c/s
