18 hp vtwin help
beperson83
05-09-2007 09:31:34
I have a 18 hp v twin briggs in my racin mower, Im not sure of the serial number. But it wont shut off when runnin lol. I replaced the key switch and the coil. That worked for a bit and then it started acting up again. I found something wasnt plugged in so I plugged it in and then it would shut off when u turn the key off. But now theres nothing unplugged but it wont shut off unless u disconnect the plug wires. I dont know whats wrong now.
Dude11
05-10-2007 14:13:45
 Re: 18 hp vtwin help in reply to beperson83, 05-09-2007 09:31:34
Hi,Joes got it nailed pretty good,I'd look for loose or bad ground.Dude
joe csuti
05-09-2007 13:32:26
Disconnect kill lead,at ign sw,with ign sw off,check from ign terminal to dash AND body of sw with ohmmeter or powered test lite,reading should be 0 ohms or you should get a light,you may have rust or paint between sw body & dash or a bad ign sw,also check for continuity between battery neg & dash where ign sw mounted,you may have a loose or high resistance connection between dash & chassis,if all of above checks out best guess is you have a bad wire terminal somewhere in harness.Try this,locate & disconnect ign kill lead where it exits eng,start eng,ground kill lead to eng with a jumper,if eng dies,problem in wiring harness or on tractor,if eng doesn't die,problem on eng(bad terminal on wire,loose connection at coil,or possible broken wire between tab on coil & windings inside coil)
