1972 110 Mower
JD Gimpl
06-15-2007 16:12:22
I am looking at a 1972 110 Mower with a deck. Any idea how much its worth.
The owner says the piston is out but still runs. He said he was mowing and it just popped into nuetral and he can't get it in gear. but still runs. Any idea on what could be wrong.
Thanks JD Gimpl
dhermesc
06-18-2007 06:05:14
 Re: 1972 110 Mower in reply to JD Gimpl, 06-15-2007 16:12:22
What exactly does he mean by "the piston is out but still runs"? I agree with the other poster, bad engine, bad transmission its worth the value of the deck and tires - $50-$60.
I just bought a good running 110 (1974 or so) with year old blades and belts for $200. If have discovered it has a small clutch issue (needs bushings on worn shaft).
BUTCH GA.
06-16-2007 03:51:24
J D i just put 3 gears in my 1971 110 and the parts alone cost over 300 dollars. Unless you access to cheap parts with engine trouble and rear end trouble it's not worth much. Lundell tractors in Kiron Iowa ph#712-675-4341 is a good source for parts.I found them after i bought my parts from John Deere. call them and see what some of those parts cost before you by it.
