1969 Bolens w/ Wisconsin TRA-10D
Jim Edwards
07-17-2007 18:02:15
My 1969 Bolens still runs great even after 38 years, but recently it has begun to burn out the coil after about an hour mowing. It has a 12 volt negative ground system. I have pictures of the wiring diagram from the orginal owners manual for those who are interested. Any ideas?
jdemaris
07-19-2007 08:34:11
 Re: 1969 Bolens w/ Wisconsin TRA-10D in reply to Jim Edwards, 07-17-2007 18:02:15
There are many coils that will work just fine. I've got one old Bolens with a TRA-10D that I put a coil from a 64 Chevy on - back in early 70s. Still works fine. It tended to burn points at first until I installed a ballast resistor. Also got an 800 Bolens with a S7D that I converted, a long time ago to battery IGN - and it too has a GM coil. I've been using it for over 30 years (also has a resistor). Same goes for my Shaw R-9 tractor with a TED, two-cylinder Wisconsin. The OEM coils offered by Wisconsin for your engine were - YF-41A-S1 for 12 volt, or YF-11 for 6 volt. You can buy a generic small engine 12 volt coil with a built in resistor at NAPA. Ask for NAPA small engine parts number 7-01634.
Bob
07-17-2007 21:41:10
Get the correct coil.
A generic automotive coil does not have the correct primary winding resistance to cope with the unusual dwell of these one-cylinder engines, and will heat up and fail.
If you can't find the correct coil for the Wisconsin, I would THINK a coil for a K-series Kohler would be a good choice.
