18hp b/s twin cyl
chevyx305
09-02-2007 11:04:37
I have a 18hp twin cyld engine has no spark in either cylinder please help THANKS
chevyx305
09-11-2007 17:06:54
 Re: 18hp b/s twin cyl i was wrong is 26 hp in reply to chevyx305, 09-02-2007 11:04:37
I was wrong about the hp it is 26. I tried what you guys told me I have not found the diode just a connection where both small coil wires are tied together no power there up to coils Im lost
chevyx305
09-04-2007 13:36:58
 Re: 18hp b/s twin cyl in reply to chevyx305, 09-02-2007 11:04:37
Thanks guys I wiil check these items and will get back to you
El Toro
09-03-2007 13:27:04
I read an article about these engines having problems with these coils/modules not lasting very long. Someone posted a response and said he thinks the battery voltage is getting to the modules and ruining them. You could check your wiring to this module with a volt meter with the ignition on and there should not be any voltage present. Hal
El Toro
09-02-2007 12:38:46
Could be the coil/electronic module that is defective. I think the part number is 394891 you can call this toll free number probably on Tuesday
along the engine's model and type numbers. They can tell you if that is the right number, if it is they have them for around $30.00. Hal
1-800-501-8061. Hal
joe csuti
09-02-2007 12:35:23
If eng mounted on tractor,locate & disconnect ign kill lead coming from ign sw at eng,crank eng,if you have spark now,it's one of the safety sw's on tractor or possibly the ign sw,if still no spark,then problem on eng,bad diode lead,ign module or oil pressure sw(if eng has).
