18.5 hp briggs oposing twin
darndt
09-23-2007 16:28:38
I have a 18.5 i/c twin flat head that I am having probs starting. the starter wont spin the engine it will barely turn it over even when I jumper it right to the starter with a knowen good battery. Ithink its the starter draging but is there something else I should look at its worse when engine is hot.
joe csuti
09-25-2007 17:59:03
 Re: 18.5 hp briggs oposing twin in reply to darndt, 09-23-2007 16:28:38
If you can move shaft side to side a 1/4" & brushes are also bad,it's probably quicker & easier to buy a new starter,check a local dealer in your area and see if repair parts are even avail & cost of same,see what dealer wants for a new one,then check around on ebay & mower parts dealers online.
darndt
09-25-2007 14:46:55
Took starter off the bushens in the top is bad the the starter shaft can move about a quater of inch sidewas is it replaceable or do i have to get new starter
darndt
09-23-2007 17:43:53
Thanks for info it spins freely with plugs out I will check the brushes ect. also the starter gets hot fast
joe csuti
09-23-2007 17:05:53
Right now it sounds like you have bad brushes or possibly worn bearings in starter or starter drive,before removing starter & dissassembling,check several other things,remove both plugs & turn eng over by hand,same should turn over freely,if not check that belts for trans & mower are fully disengaging motor drive pulley,if belts disengaged & eng not spinning free,then you have a mech problem in eng,if eng does spin free check out starter.
T.R.K.
09-24-2007 08:12:23
 Re: 18.5 hp briggs oposing twin in reply to joe csuti, 09-23-2007 17:05:53
Another thought is the valve clearance is too great. and the starter cant' crank the engine over compression.
I've never seen this happen on a Briggs opposed but it can be a problem on their V-twins.
Also, does the starter gear slide freely up and down its spiral on the starter shaft? The starter gets a lttle edge if it can already be turning when the load of the engine comes on it.
One thing I witnessed on a V-twin: The starter gear was binding in the ring gear on the flywheel to the point it took all the starter's power to force them to mesh and turn.
