Carburetor rebuild kit for HH120
queen of spades
01-02-2008 07:01:45
Anyone know what part number I should search for? I didn't find anything googling HH120 carburetor rebuild kit.
Thanks!
queen of spades
01-02-2008 11:46:13
 Re: Carburetor rebuild kit for HH120 in reply to flashback, 01-02-2008 07:01:45
The float is part number 27105.
queen of spades
01-02-2008 11:44:11
 Re: Carburetor rebuild kit for HH120 in reply to SLH IN MO, 01-02-2008 07:01:45
I found the part number. The SS12 carb repair kit is part number: TEC-32412A, $37.21 retail.
JT
01-02-2008 18:22:52
 Re: Carburetor rebuild kit for HH120 in reply to queen of spades, 01-02-2008 11:44:11
let me check and see if I have one in my old parts bins or can cross it to a Wabro number, maybe save you a few dollars.
Jim
queen of spades
01-02-2008 08:39:17
 Re: Carburetor rebuild kit for HH120 in reply to JoeK(WI), 01-02-2008 07:01:45
JT said: (quoted from post at 11:40:55 01/02/08) Get me the spec number off the engine and I will give you the part number. it should have a Walbro carb on it and they are real simple to work on. Normally I can get them running without spending the 20-30 dollars that ir cost to get the kit. If you can find the number off the carb, I might be able to get you a number through Walbro a lot cheaper. then you can look local to find it instead of paying the shipping to get it to you.
Jim
I don't have the spec number because the plate is missing. Can you use the serial number? That is 143602022. It goes on a 1971 Sears Suburban SS12. Thank you.
JT
01-02-2008 07:40:55
 Re: Carburetor rebuild kit for HH120 in reply to queen of spades, 01-02-2008 07:01:45
Jim
Dude11
01-02-2008 07:14:28
First,you will need to indentify your carb.Walbro?What's it on a 12hp.Tec.engine?if so,kit# is found thru Sears,#32412A.Or maybe you can find it on ebay.It won't have the newer main nozzle in it.You will need to find that for sure for a rebuild.I got mine locally.And by the way,these kits are pricey!!Once everything is aquired,I have a sure-fire cleaning tip,shoot me an email for details.Good luck,Dude11
