1882 slow hydro and weak
buddy1204
01-03-2008 14:09:06
hi need some more help,my 1882 cub is real slow on any grade,have changed fluid,filter,and taken out and cleaned hydro valves as told in my old post butit seems to be geting worse, on the linkage shaft if i adjust it so that it will pull great up and faster on leavel ground then i have nothing in reverse,i have been running it so they both work on forward and rev but she is a bit slow and weak on grades,any more help i do thank you all much,maybe im missing something on adjustment and i have not even touched the plate on side of hydro with the spring but maybe someone can piont me on right directipn,thanks bud
buddy1204
01-06-2008 06:51:39
 Re: 1882 slow hydro and weak in reply to buddy1204, 01-03-2008 14:09:06
hi, i just want to say i sure do thank each and everyone who had helped me with this and all how have helped in the past, thanks for everything, and have a great newyear, bud
R Bedell
01-06-2008 04:15:31
 Re: 1882 slow hydro and weak in reply to Scott PA, 01-03-2008 14:09:06
The problem lies within controlling the Hydro Unit. Somewhere in the Linkages or Adjustments. Click on this link and check to see if this applies.....Repair
mr ariens
01-04-2008 20:36:43
shift linkage is loose or worn out
i repaired it on a lot of older cubsart
buddy1204
01-05-2008 00:17:33
 Re: 1882 slow hydro and weak in reply to mr ariens, 01-04-2008 20:36:43
is the shift linkage on the side of hydro with the spring and is it very dificulte to set -adjust after i purchase new,any help i thank you, bud
buddy1204
01-04-2008 07:28:36
forgot to mention this is shaft drive, it is a 1882 super garden cub cadet think 1994 year,any help i thank you, bud
Kentb of SWMO
01-04-2008 06:27:30
Belt or shaft drive? If belt drive check the belt. I do not know the model nimbers but CC use to be all shaft drive but MTD can screw anything up.
Kent
buddy1204
01-03-2008 19:07:12
just wanted to say that it does have plenty of pullin,if i pull something it works just fine ,but is just very slow at doing it,any help i sure do thank you all,if someone can just point me in the right direction just wanting to get it right,thanks,bud
