16hp kohler shakes
don , ohio
01-13-2008 04:19:30
hi anybody, i have a 1650 cub cadet that i got from my dad. it has a 16hp kohler skakes whole tractor at idel but otherwise runs good,tried adjusting carb. no good. my dad had it to a cub dealer and they told him it needed motor mounts.but i cant see why mounts would make it shake it smoothes out when throttled up any ideas
stronics
01-13-2008 17:41:54
 Re: 16hp kohler shakes in reply to don , ohio, 01-13-2008 04:19:30
16's really shake even with new mounts at idle. The trick is to not run them there. The more HP the more it shakes with the Kohler single.
David
JayIHMan
01-13-2008 16:13:59
Zach's Machine on E Bay makes and sells solid motor mounts for cubs, I bought a set and you won't be disapointed. Cost me about 20 dollars
G Cooper
01-13-2008 16:07:39
I have replaced the iso mounts on three of my quiet lines using the rubber grommets out of auto shock absorbers. They work very well and are very inexpensive compared to the price they want at the cub dealer.
don , ohio
01-13-2008 14:41:31
 Re: 16hp kohler shakes,thanks for the replys in reply to don , ohio, 01-13-2008 04:19:30
i wasnt questioning the dealer,i just didnt think mounts would make it shake that much.the cub dealer wanted $400.00 to replace. thanks
JT
01-13-2008 20:05:26
 Re: 16hp kohler shakes,thanks for the replys in reply to don , ohio, 01-13-2008 14:41:31
That sounds a little high, it should take less than three hours to do, And last bushing kit I priced was about $40.00 I think, don't know his labor rate, but I would get about $250.00-$300.00 to do it in my shop. If you have run it very long, it may need other things also.
Jim
Kentb of SWMO
01-13-2008 14:10:09
There is a lot of weight flying around in a K-341/16 HP Kohler. That is why it shakes. CC went for the rubber mount instead of the internal balancers. Even with new mount it will shake some. The new mounts will also help the belt tention on the mule rtive to the mower deck if you use the CC to mow with. Kent
JT
01-13-2008 08:15:11
Needs new iso mounts. Someone used to make some to put in to make them solid, but have not seen any lately.My 1450 shakes bad, it has bad mounts. Why do you question the dealer, he dworks on them for a living and obviously he has seen this before. Having bad mounts are the same as having an engine not bolted down. You better get them replaced quick or it will eventually break some high dollar parts!
skip176
01-13-2008 06:26:23
I dont own any quiet lines but I worked on a 1450 yesterday that did the same thing. This is commen ad yes its the iso mounts. You need to fix it soon or you nice cub will suffer from a magor failure. All the single cylinder cubs shake but Ill bet yours is the mounts. My 14hp do it but he 10's and 12's not as bad.
lucas boy
01-13-2008 07:58:58
 Re: 16hp kohler shakes in reply to skip176, 01-13-2008 06:26:23
my 1650 shakes at idle.check rubber mmounts by pushing on engine side to side. lucas
