JD 850 Hay Rake Wheel
Gary1(UT)
12-05-2006 09:18:21
I am hoping someone can tell me where to find a replacement tire rim for a JD 850 side delivery hay rake. I have found a free rake but it is missing the right tire and rim. I am located in central Utah. Any suggestions are appreciated!
Sid
12-06-2006 01:51:19
 Re: JD 850 Hay Rake Wheel in reply to Gary1(UT), 12-05-2006 09:18:21
Get one to match the left tire and rim.
Gary1(UT)
12-05-2006 12:42:15
Bob,
Thanks for the reply, I will need to check the rim size. I am not sure but seem to remember 6 lug studs on the end of the axle. I will check and get back to you by E-mail. Thanks again.
Bob
12-05-2006 11:32:07
I have some fairly narrow wheels from DEERE trailer mowers, with 4-hole mounting patterns, and was wondering if they'd fit, so I looked on jdparts.com.
The rake is too old to be in the on-line parts system, so I couldn't look up the wheel.
What is the width, size, and bolt pattern of the rim you need?
Here's a photo from Implement Photos on this site:
Third Party Image
