I have had a tractor for over 3 years now but my knowledge of the 3 pt. system is very limited because my 202 MF has worn a frame mounted backhoe all the time I've had it and probably for the past 50 years or more. I don't believe it has ever been used.
I am now rebuilding the 3pt hitch, basically cleaning everything and getting things moving again. So once it is all said and done I need to get all the outside pieces to get things hooked up but I'm seeing a bewildering number of different items so I'm not sure just what I need.
So as I understand it I need lower lift arms, a top link, leveling rod/box, stabilizers etc. but I have no idea of what lengths etc. that I need.
For what it's worth, the 202 is pretty much a heavy duty 35 so I'm thinking the 3 pt parts should be the same.
