Made it all 47 miles home just fine, just glad I did it early Sat morning, as it is still kind of wide, even with the hitch swung over.
Got it hooked up to the M, and all seems ok, but there is a fair amount of slop in that upper sickle driver pivot. Need to check that for wear, and the sprocket on the lower conditioner roll, RH side, is loose. From what I can tell, this was a common issue.
Got a little work to do, but I think it'll be a decent machine.
