IH mower id???
Tractor Dan
03-31-2003 14:05:26
i have a IH sickel bar mower and its either a 25 or a 25v can anyone tell me the difference so i know what i have picture or just description thank you
Hugh MacKay
03-31-2003 17:22:31
 Re: IH mower id??? in reply to Tractor Dan, 03-31-2003 14:05:26
Dan: I found your mower in book 150 Years of IH. The picture isn't clear enough to give specifics. What he does say is the 25 had a plain lift while 25V had a vertical lift. I would have thought any lift of a mower would be vertical. The mower pictured is 25V, mounted on a Farmall M. I can see what appears to be a hand lever between operator and right rear wheel, coming from mower. These mowers were introduced in 1940 and by 1950, 193,000 had been sold. This mower also has a rear caster wheel. I think caster wheel was on both.
Larry
04-07-2003 13:44:37
 Re: Re: IH mower id??? in reply to Hugh MacKay, 03-31-2003 17:22:31
I may be wrong, but I think the difference between plain lift and vertical lift is that the plain would pick up the cutterbar but leave it horizontal, and the vertical lift would also stand up the cutterbar.
