Pulling pistons out of Mod. B
Jim Hammel
06-06-2003 06:06:13
Can the pistons be pulled out the top of the block on a "B" without using a ridge reamer?? If not can a ridge reamer be used with the block still on the tractor? I have one connecting rod I need to remove.
Thanks, Jim H.
Chuck W
06-06-2003 13:04:44
 Re: pulling pistons out of Mod. B in reply to Jim Hammel, 06-06-2003 06:06:13
I use a small dremel and just cut the burr off the grove to prevent any land damages. I have pushed them out without doing this also...you need the sharp edge beviled down to prevent damage to the new rings. I never go as drastic as a ridge reemer. You can also you a grinder but be careful to just slight touch the grove. All one needs to do is de burr.
F-I-T
06-06-2003 12:49:47
Jim:
If there's a pronounced ridge it really should be removed, and yes, if you have the right type ridge reamer, you can ridge ream while the block is still in the tractor.
Frank-in-Tallahassee
70D // 855
