more on the A head
Jim 52G
04-06-2006 14:00:14
Thanks lynard for the info on my last question. just reassuring myself here on the head interchange due to cracked 45A head. the 45A head and 50A head have the same piece that goes under one head nut for oiling the tappets. I"m trying to figure how the oil gets to that piece from the block and thru the head. some hole are a little different but the napa dealer says they use the same head gasket. so you think it will get oil to the tappets with the 50A head? thanks
Mike n Mo
04-06-2006 16:47:41
 Re: more on the A head in reply to Jim 52G , 04-06-2006 14:00:14
The head gaskets are the same , as the parts man told you. The oil is pumped thru the block and head thru a passage from the crankcase, and that passage is located in the same place for all the styled tractors. It should not be a problem for you. Mike
