Two cyl mag Jul/Aug 91, B trans speeds?
1936
11-29-2006 12:25:53
Check your archive issue of Jul/Aug Page 16 on transmission speeds.
The keys A thru E list trt serial numbers, trans numbers, and how the trt was equiped for the range of speeds. A. Steel wheels serial 1000 - 36814, fourth gear a speed of 3.75 MPH. D. Trans AB 1298R, serial number 14783 - 58246 with 7.50 X 36 rubber tires list fourth gear speed 9.35 MPH.
Question? Serial numbers 1000 to 36814 on cut offs with 36 inch rubber speed be 9.35?
Also listed two trans part numbers.
High speed AB 1298 R
Low speed AB 1432 R
By chnace would these numbers be on the case of the trt?
not obvious
11-29-2006 16:52:15
 Re: Two cyl mag Jul/Aug 91, B trans speeds? in reply to 1936, 11-29-2006 12:25:53
your question isn't very clear. What do you want to know?
