open shaft A
jlmcgee
02-27-2007 15:29:25
Can anyone tell me the last serial #'s on the unstyled A's that had open fan shafts? Thanks.
Kent WI
02-27-2007 19:12:36
 Re: open shaft A in reply to jlmcgee, 02-27-2007 15:29:25
Serial Number 414808 was the last A built with an open fan shaft and from what I understand is still exist. Serial Number 414809 was built with the fan shaft fully enclosed.
Kent
ram ranch
02-27-2007 20:01:00
 Re: open shaft A in reply to Kent WI, 02-27-2007 19:12:36
The serial number 414809 was the first change from an "open" to an enclosed fanshaft. However it is stated in J.R. Hobbs, "although records show that tractor number 414800 was built was the first 'A' to be built with the enclosed fanshaft(J.R.Hobbs ,THE JOHN DEERE UNSTYLED LETTER SERIES)." So, was it 414808 or 414799?
Kent WI
02-28-2007 06:21:42
 Re: open shaft A in reply to ram ranch, 02-27-2007 20:01:00
My source of information is "The Unstyled Model A" by Wes Malcolm. Wes spent a lot of time in doing research for his book and has kept a log of the open fan shaft A's and knows the location of 414808. But then again I am not going to argue with J.R.
In regards to the fan shaft Detwilers is making reproduction open fan shafts 715 659 4252
Kent
ram ranch
02-27-2007 16:01:04
some were between number 414800-414809
jlmcgee
02-27-2007 21:18:55
 Re: open shaft A in reply to ram ranch, 02-27-2007 16:01:04
Thanks for the help. We have a tractor that should have an open shaft. Now all I need to do is find a good used fan shaft.
If anyone knows where I can find one let me know. Thanks again
ram ranch
02-28-2007 05:43:31
 Re: open shaft A in reply to jlmcgee, 02-27-2007 21:18:55
a good used open fan shaft?
jlmcgee
02-28-2007 07:33:12
 Re: open shaft A in reply to ram ranch, 02-28-2007 05:43:31
Yes I need a good used open fan shaft for my A if anyone has one. Thanks Johnny.
