JD 4040 hydraulic leak has us stumped!!!!!!
jharold
04-20-2007 20:08:47
My dad has a powershift 4040 that will leak oil out of the left side of the 2 point. It is the top part of the 2 point arm where it goes into the housing. The deere mechanics say that is not possible because that part is not under pressure. It is a totally random leak that comes and goes but when it comes it leaves a trail behind the tractor. Any ideas????? ?
G/MAN
04-22-2007 10:52:22
 Re: JD 4040 hydraulic leak has us stumped!!!!!! in reply to jharold , 04-20-2007 20:08:47
It's not uncommon for a rockshaft seal to leak there. As was mentioned, o-rings and lip seals do the sealing. If the seals get old and tired, there is excessive play in the rockshaft bushings, or the oil holes that allow oil to drain from between the o-ring and lip seal get plugged up with crud, they can easily leak. Apparently those Deere mechanics haven't had too many rockshaft housings off, because they don't know what they're talking about.
HTR
04-21-2007 06:05:05
If the inner Oring in the rockshaft housing is bad, the dust seal where your leak is , will have charge pump pressure on it.
deereisoverpriced
04-20-2007 21:47:38
buy a red tractor
95CS
04-21-2007 09:11:16
 Re: JD 4040 hydraulic leak has us stumped!!!!!! in reply to deereisoverpriced, 04-20-2007 21:47:38
Buy a red tractor? Why? Because they are cheap? Did it ever occur to you, micro-brain, that there's a reason "red" tractors are cheap? Lousy hydraulic systems are just one of the long list of reasons "red" tractors are cheap.
Jim in AK
04-21-2007 08:57:46
deereisoverpriced,
Ya, why don"t take a flying leap in to financial disaster?
Jim
720 in pa
04-21-2007 08:13:26
deereisoverpriced why do you even visit this talk forum?
buickanddeere
04-21-2007 20:46:36
 Re: JD 4040 hydraulic leak has us stumped!!!!!! in reply to 720 in pa, 04-21-2007 08:13:26
deereisoverpriced gets on the computer when Mommy isn't watching.
