Added a PTO pump on a 50
Bob
12-21-2001 10:53:52
I just added a 22 gpm PTO pump onto a MF 50. I could not figure out how to put a pump on the front because of the steering. I put on an auxillary tank also, mounted on the right side under the spools, bolted on to the loader brackets. The pump is to run the loader and has two remotes, mainly for my wood-splitter for which I wanted power and speed. It is a bit of a pain when you want to run a piece of machinery like a bushhog or a plow as you have to remove the pump. I was wondering if I could mount the pump to one side of the PTO shaft, maybe mounting a gear onto the PTO shaft and running a motorcycle chain around it to another slave gear that would run the pump. This would mean I could leave the pump permanently on the tractor, not having to remove it each time I don't need it. Has anyone ever seen such an animal? My problem seems to be space. Any ideas?
Kelly
12-30-2001 17:10:39
 Re: Added a PTO pump on a 50 in reply to Bob, 12-21-2001 10:53:52
Why didn't you just mount a selector valve on top of your plate under the seat? I have one that I can select either the loader, 3 pt. hitch, or a spool valve mounted to the fender for things like a log splitter. Purchased it from CT farm and country. Good luck!
bob
12-22-2001 10:17:53
don,t know what kind of pump yoou got but i have a Prince and on it i can put shaft inside and run pump and pto equipment at same time . factory i sin sioux city Ia or northern handles them
