oil filler on Massey Harris 44
Bob Myers
03-25-2004 14:00:47
I have a very dumb question. I'm fixing up a 1950 Massey Harris 44. Where is the oil filler? I see a cap on left side of engine but the hydraulic pump is connected to this same housing. It looks like a hydraulic system was added later. There is a small 1/4 inch line that runs from tank in front of radiator and is attached about an inch behind this filler cap that I see. Is this my oil filler cap? and what is that line for. Thanks, Bob
marlowe
03-25-2004 15:49:14
 Re: oil filler on Massey Harris 44 in reply to Bob Myers, 03-25-2004 14:00:47
your hyd. system is oem thats the way they came for live hyd.and DW told you about the rest
DW
03-25-2004 15:05:46
Yes that is your oil filler cap. The small tube is the vent for your hydraulic tank. If you run the oil level to high & have a fast dropping single action cylinder you can force some hyd. oil into the motor base. Some of the original MH hyd tanks also had the oil return fitting installed very low.
