CYLINDER LINERS
CHRIS GA.
10-20-2005 15:11:20
LOOKING FOR BEST METHOD TO PULL CYLINDER LINERS OUT OF MF 250. TRYED UNIVERSAL LINER PULLER BUT LINER SO THIN IT WOULD NOT GRAB THE EDGE. HAVE BEEN TOLD OF DRY ICE, BUT WOULD RATHER USE TOOL TO PULL
MasseyMan 1970
11-05-2005 16:32:15
 Re: CYLINDER LINERS in reply to CHRIS GA., 10-20-2005 15:11:20
Use perkins sleeve puller. Not as hard as you think if you have the correct tools
CHRIS GA.
11-05-2005 18:27:42
 Re: CYLINDER LINERS in reply to MasseyMan 1970, 11-05-2005 16:32:15
MASSEYMAN, DO YOU KNOW THE TOOL PART NUMBER ? I NOW HAVE TWO ENGINES TO PULL LINERS ON, WILL HAVE TO TRY SOMETHING SOON, RIGHT OR WRONG!!!!
Leland
10-21-2005 19:30:13
Dry sleves are a pain no matter what I have found out .
marlowe
10-20-2005 17:44:04
[[[[ A WELDER ]]]] make sure crank coverd REAL good or better still remove it. pull a fast arch on the sleave the full length in two spots and they will fall out. perkins are a bitc- to pull pullers will and can dig in to the side wall of the block then you have a junk block. welder trick is the best and i have done 30+ perkins
marlowe
10-20-2005 17:47:15
 Re: CYLINDER LINERS in reply to marlowe, 10-20-2005 17:44:04
P.S. to put in freeze colder the better work FAST [DO NOT POUND]
Rlach
10-20-2005 17:18:31
I did the same job on a AD4203 long time ago; an adapter was machined and each liner was pushed out of the cylinders. New liners were frozen in dry ice before installation, it is much easier that way.
Rlach
GaryF
10-20-2005 16:21:31
The liners on my 135 were pulled with a hydraulic liner puller (reminded me of a jack). There are some very crude ways of pulling them usually with success
