1135 PTO Update
Briar Creek Sta
09-19-2007 17:46:03
Well, I started tearing the tractor down once again.
When I took the The PTO housing off I decided to turn the pto over by hand and see if I could locate where the noise was coming from. The rattle seems to be coming from the top gear (the one that the shaft from the clutch goes into). I can also grab ahold of this gear and move it in and out maybe 1/8 of an inch.
My question is...Is this play in the top gear normal? Do the spacers take up this? Or do I have another problem?
Also noticed a little play in the PTO output as well. Not as much as the input gear but there is a little there. It also looks as though the output is leaking a little.
Any help would be great
Briar Creek Stables
09-20-2007 16:05:30
 Re: 1135 PTO Update - Problem Solved in reply to Briar Creek Stables, 09-19-2007 17:46:03
third party image
Found the problem!!!!! I turned each gear in the PTO housing by hand starting from the top input shaft and woring my way down. I removed each gear, checked the bearings and went to the next. The cluster gear had a little different feel to it and had a little suprise waiting for me at the other end.
The thrush washer on the housing side melted itself to the cluster gear. It also took out the housing bearing for the cluster gear. Parts are ordered and hopefully this machine will not eat another pto clutch. I have no idea how I overlooked this the last time I went through the bearings.
janne
09-21-2007 00:05:01
 Re: 1135 PTO Update - Problem Solved in reply to Briar Creek Stables, 09-20-2007 16:05:30
so nice to hear you finally found the problem. i hope it will give you good service once again.
