Re: Massey Ferguson 35 Diesel: 3 Point Hitch wont go down
DavidP, South W
01-21-2008 15:02:27
Hi,
I think Dean is on the right trach saying that the control valve is stuck in the pumping position. This I believe is not the cause of the problem. I think that you will find that the aliminium 'oscillator' under the pump is broken. Driven by the eccentric on the pump shaft it sets up a rocking motion which prevents the control valve from sticking. Later tractors had a steel oscillator.
I would suggest that you drain the oil to the level of the bottom bolt and remove the RH side cover. You will see the pump lever at the bottom. Operate the control lever to 'Down' and you should see the pump lever move forward to the discharge position. If it does no do so you can operate the pump lever by hand and the 3-pt should go down.
DavidP, South Wales
