Northern Digital Tach, revisited, my experience
rob 8N11071 KS
06-13-2001 14:13:23
Not too good.
The hour meter resets each time I run the tractor, and it reads 2000-4000 rpm in an idle and fast idle. NO WAY, my idle is that fast.
Greg
06-14-2001 05:24:58
 Re: Northern Digital Tach, revisited, my experience in reply to rob 8N11071 KS , 06-13-2001 14:13:23
Dave#1 is correct about the battery. I have used a couple of these tach's for awhile. I have one on my 8N and get the same rpm readings you do. Since it has an inductive pick-up on one lead, and the other goes to ground, I have a suspicion it is sensitive enough that it is reading every ignition voltage spike. In other words, it's seeing all four plugs fire. If you divide your readings by 4, they are probably about right. I am still messing with mine, trying to find a way around it. FWIW
Larry 8N75381
06-14-2001 07:35:18
 Re: Re: Northern Digital Tach, revisited, my experience in reply to Greg, 06-14-2001 05:24:58
Greg,
Your comment about the ground and picking up all four spikes rang a bell in my head. Had a similar problem related to a bad ground in an old computer I was trouble shooting. The clock signal for the logic was distributed to several driver cards through out the chassis. These drivers had a low impedence so they could drive many cards at once. The power for the logic cards was jumpered from one card slot to the next all across the row of cards. Every so often the ground was also tied to the frame for added grounding. Right where the driver card was was one of these grounding links. It was loose and not making contact. The result was that the driver was "jerking" the ground up and down. So the adjecent cards had a moving reference for the voltage of the incoming signals. SO if the incoming signal was high AND at the same time the ground had been pulled high by the driver, the logic in the card thought the incoming signal was zero NOT one as it really was!
You might try this on your tach. Take a HEAVY gage wire from the battery ground (or at least the point where the ground lead is bolted to the chassis) to the closest point you can get on the tach ground lead to the tach case. That should eliminate any chance that variations in the groung potential is causing you trouble.
HTH
Larry
tlak
06-13-2001 14:45:27
Car radios have another wire that is hot all the time to keep your radio memory, which may be why your hour meter resets. Also I would contact the company and see if it needs to be recalibrated or returned.
dave#1
06-14-2001 03:32:13
 Re: Re: Northern Digital Tach, revisited, my experience in reply to tlak, 06-13-2001 14:45:27
I doubt the meter needs power all the time to keep the hour meter from reseting, I would think that's why it has a internal lithium battery.
later,dave
tlak
06-14-2001 04:22:38
 Re: Re: Re: Northern Digital Tach, revisited, my experience in reply to dave#1, 06-14-2001 03:32:13
So since its resetting and acting strange it could all be a dead or weak battery. Might be a shelf life thing, a little old before they sent it out.
dave#1
06-14-2001 14:43:38
 Re: Re: Re: Re: Northern Digital Tach, revisited, my experience in reply to tlak, 06-14-2001 04:22:38
That's what it sounds like to me but it also sounds like he has 2 problems that are'nt related(I think) The first is the false reading due to....?????, and the second is,that the meter is not holding memory,which like you said, might be a bad-weak lithium battery ??? Who knows?
later,dave
