Rotary cutter: improving cut?
rob 8N11071 KS
06-14-2001 09:25:40
(I started to post this to Implement Alley, but realized I need this answered in an "N context")
I'd would appreciate tips on how to improve the quality of cut from my 5 ft rotary mower. I mow in 1st, use limiter chains and anti-sway bars. I keep the front lower than the back, but I am now questioning that practice. I sharpen the blades after every two mowing sessions.
Am I expecting too much? I thought for sure I read an article/message about some tips to get a near-finish-mower cut from a 'hog.
I blew my tractor $ on a new engine, so I can't buy a finish mower this year.
Sal
06-14-2001 19:04:04
 Re: rotary cutter: improving cut? in reply to rob 8N11071 KS , 06-14-2001 09:25:40
I have my Bush Hog brand owners manual right here.
It says to keep the front a few inches lower when you have rough ground, thick stuff to cut...it will also be easier on the tractor this way
It then goes on to say keep the deck level when you want more fine cut, by keeping the deck level what you are cutting will be cut twice and it will shred it more finely...this is only for lighter grasses and weeds and smooth ground.
I have followed the manual and they are right.
If you have the model number you can contact Bush Hog and they will send you a manual...see their web site....www.bushhog.com I think.
Mike 8N
06-14-2001 10:52:34
I always keep the front a little lower for safety, it keeps stuff from flying out the front. You could try a higher cut on the first pass so there is less grass being cut on the final pass. Also slow is better, but if your in first gear, you can't get much slower without a step down tranny.
Good luck.
Mike S
06-14-2001 09:53:37
I know lots of folks say to keep the front lower than the back to keep it from clogging up, but I just set mine level and it seems to work fine. It will not cut as well as a finish mower on decent grass. Keeping the blades sharp is certainly important but their biggest claim to fame is the ability to take down weeds, small bushes and scrub trees. Some folks call them a shredder and that is what they do best. Growing season is not the time to be finding a deal on a used finish mower, but you just might. A friend of mine just bought a used Bush Hog brand finish mower and gave 200 for it. All it needed was a new belt.
rob 8N11071 KS
06-14-2001 10:34:14
 Re: Re: rotary cutter: improving cut? in reply to Mike S, 06-14-2001 09:53:37
I always have my eye out for implements, so I have been "shopping" for a used finish mower for over a year. I don't seem to find any good deals, even at auctions.
Mike S
06-14-2001 09:53:41
