Order Ford 8N Parts Online
FORD 8N carb
Rob
04-07-2000 04:20:19
Help I have a 8N. I had the carb rebuilt but the tractor runs real rough especially at idle. I tried adjusting the main power adjust needle, but the only way the tractor will run good is if I take the power adjust needle right out. With it completely out it idles and runs perfect any ideas or help would be appreciated. thanks ROB
Nolan
04-07-2000 04:41:57
 Re: FORD 8N carb in reply to Rob, 04-07-2000 04:20:19
Two things jump to mind quickly.
One is the float. Sinking or simply set too low.
Two is air leaks.
